I have a quick question how can i start the work flow processor at the startup.
I have to goto Form Tutorial_WorkflowProcessor and click on “START”.
Only when i click the START. My work flow is working fine. I just want to start it automatically i dont need to goto this form and start the processor every time.
How can i do this please guide.
Thanks and regards.
Harish
July 5, 2011, 7:42am
#2
You have to setup workflow to run as batch server. You can find step by step guidance on Workflow batch set up here - http://www.packtpub.com/article/setup-configuration-workflow-microsoft-dynamics-administration
I have the same issue in Ax2012, when i go to run this process by AOT then workflow works, otherwise nothing happens.
kindly some buddy guide me what to do.
Regards
sarfaraz
Vinod.p
November 2, 2015, 12:55pm
#4
Hi Harish…
Nice Article… But it is in 2009 Platform… Is this possible can you have the link in 2012 Platform
Bec I am facing the Same issue
Dear All,
Just do the below setups, Before configuring the batch server,batch group…etc…
System administration->Area page->Inquires->Batch jobs->Batch job history
Select all batch jobs history and clear the all data (Delete)
Select all batch jobs and clear the all data (Delete)
System administration → Area page → Setup->System->Server configuration
Ensure all batch server groups are in selected groups
then you can do the regular setups (Batch server,Batch group,Workflow infrastructure configuration wizard…etc…
I’m sure definitely it will work
Kanagaraj Priyasamy
