Standard Capacity Cost
Hi ,
I am doing the following steps : After each released order – I do manual consumption —then manual output …then change status of the released Prod order to finished Prod order
at the moment of refreshing the Released Production order —> going to F9 or Production Statistics
at the level of Material cost every thing is right
At the level o f Capacity cost… I am facing a problem … Standard cost for Capacity is not shown (here is my question) …while expected Capacity cost is shown
As I know This standard cost for capacity is based on standard routing .
So What it can be ?? why this field is not shown ? In cronus is shown in the old finished Production orders , But also is not shown at any new released production order that I am trying to do .
Thank you
Have you created a routing for the Assembly?
Have you ste the Production Routing No. on the Item card to point to that Routing?
Have you created the Work Centres / Machine Centres with costs?
When you press F9 on production orders, standard cost is Item standard cost,
You must calculate It from Item o standard cost worksheet and apply it.
Best Regardsç
Agustí
Hi Jonathan ,
Yes for the 3 questions above , all done … that why I am still surprised why it didn’t work …
Thank you any way for you help
Hi Augusti,
I mean Capacity standard cost …if you mean the same … wher I can find the standard cost work sheet.
Thank you for your help
