Stack trace: The company SysTransactionScopeCache does not exist.
Hi there,
I am experiencing this error "Stack trace: The company SysTransactionScopeCache does not exist." when I try to submit a purchase requisition.
Does anyone know what causes this error?
It sounds like that there is a bug trying to use ‘SysTransactionScopeCache’ as a company. Look at the code in question to understand what’s going on. If you need help from us, please share the call stack and the code. If you can’t/don’t know how, ask a developer (if you have a development team) or your implementation partner.
Hi Martin,
This is the stack trace found in the infolog:
Stack trace
(S)\Classes\SourceDocumentLineProcessor\submitSourceDocumentLineServer - line 66
(S)\Classes\SourceDocumentLineProcessor\submitSourceDocumentLine - line 51
(S)\Classes\SourceDocumentProcessor\submitSourceDocumentLinesForHeader - line 71
(S)\Classes\SourceDocumentProcessorFacade\submitSourceDocumentLinesForHeader - line 53
(S)\Classes\PurchReqWorkflow\validateAccountingDistributions - line 21
(C)\Classes\PurchReqWorkflow\canSubmit - line 36
(C)\Classes\PurchReqWorkflow\main - line 20
(C)\Classes\FormFunctionButtonControl\Clicked
This could help, unfortunately I don’t have any AX 2012 environment on hand. Hopefully I’ll be able to take a look tomorrow.
If you’re a developer, use the debugger to see understand what’s happening in code.
Thanks, Martin.
While hoping for your insights by tomorrow, I will try debugging this error.
Can you also show your code in,
Here Kranthi, the line highlighted in yellow is the 66th line of the code…
private static server void submitSourceDocumentLineServer(
SourceDocumentLine _sourceDocumentLine,
boolean _updateImplementation,
SourceDocumentLineAccountingStatus _targetSourceDocumentLineAccountingStatus,
SourceDocumentProcessorCaller _caller,
UserId _user,
AccountingDistributionAllocationMethod _accountingDistributionAllocationMethod,
SourceDocumentLineItem _sourceDocumentLineItem = null,
AccountingPolicy _sourceDocumentLineAccountingPolicy = null,
boolean _isProcessForDocument = false,
RecordInsertList _accountingDistributionInsertList = null,
systemSequence _systemSequence = null,
boolean _doTransitionToCompletedStateAccountFullyQualifiedValidation = true,
RecordInsertList _sourceDocumentLineTmpInsertList = null
SourceDocumentLineProcessor sourceDocumentLineProcessor;
SourceDocumentLineTargetStateProvider sourceDocumentLineTargetStateProvider;
SourceDocumentLineItem sourceDocumentLineItem;
// Flush cache for source document line item
SysTransactionScopeCache::remove(classStr(SourceDocumentLineItem), [_sourceDocumentLine.RecId, _sourceDocumentLine.RecVersion]);
if (_sourceDocumentLineItem)
sourceDocumentLineItem = _sourceDocumentLineItem;
else
sourceDocumentLineItem = SourceDocumentLineItem::newFromSourceDocumentLine(_sourceDocumentLine);
sourceDocumentLineItem.parmCaller(_caller);
sourceDocumentLineTargetStateProvider = SourceDocumentLineTargetStateProvider::newTargetStateProvider(
false,
_caller,
_user,
false
sourceDocumentLineProcessor = SourceDocumentLineProcessor::newFromSourceDocumentLineImplementation(
sourceDocumentLineItem.parmSourceDocumentLineImplementation(),
sourceDocumentLineTargetStateProvider,
_caller,
_user,
false,
sourceDocumentLineItem,
_sourceDocumentLineAccountingPolicy);
sourceDocumentLineProcessor.parmDoTransToCompletedStateAccountCheck(_doTransitionToCompletedStateAccountFullyQualifiedValidation);
sourceDocumentLineProcessor.parmIsProcessForDocument(_isProcessForDocument);
if (SourceDocumentLineProcessor::doSetBasedOperationOptimization(sourceDocumentLineItem))
sourceDocumentLineProcessor.parmAccountingDistributionInsertList(_accountingDistributionInsertList);
sourceDocumentLineProcessor.parmAccountingDistributionSystemSequence(_systemSequence);
sourceDocumentLineProcessor.parmSourceDocumentLineTmpInsertList(_sourceDocumentLineTmpInsertList);
changecompany(CompanyInfo::getDataArea(sourceDocumentLineItem.parmLegalEntityRecId()))
sourceDocumentLineProcessor.submit();
It seems that CompanyInfo::getDataArea() returns ‘SysTransactionScopeCache’ for some reason. Use the debugger to see why.
I looked into the code but there is nothing I can do without being able to reproduce your problem. Please use the debugger to debug it in your environment.
