ssrs reports problem
i am creating a visual studio report and add to AOT sucessfully and add a out menu item as specific ssrs report .
when i am open menu item did not disply the output .
The below errors displayes
Error while setting server report parameters. Error message: The item ‘/DynamicsAX/CarList.AutoDesign1’ cannot be found. (rsItemNotFound)
Please help me Thanks for advance.
Taraka rama prasad
well, according to your own description, you haven’t deployed the report before trying to run it… right click on the report in AX AOT and run “Deploy”.
Janis.
Hi Prasad,
After deployment you select the proper design in menuitem properties.
