In my SSRS report I’m using a string report parameter which gets values from an AX Enum Provider Dataset. And this dataset refers to an AX base enum. I’m not using neither Data Contract nor UIBuilder class for this report.
See the contents of the Value property:
Value field: Name
Label field: Label
This works fine, but there is a strange problem, the parameter form control isn’t shown entirely, something is overshadowing it. Have you experienced this problem? If so, please share your solution. I tried restarting report server, IIS, AOS, deleting caches, etc. nothing helped.
