I’m trying this SSRS in two different environments with the same configuration.I’ve Ax2009 with SP1 and RU5.My DB is SQL Server 2008 and i’ve installed SSRS in the system.When i try to deploy SSRS,it tries to create libraries and throws me error.With the help of below link i have installed SSRS
http://daxguy.blogspot.in/2008/12/installing-ax-2009-reporting-extensions.html
And the two errors are
1)
The following components have not been installed or are not configured correctly:
AL.exe
Please consult your administrator or the documentation.
2)
One or more libraries built with warnings. Please see MSBuild log at C:\Users\rajarajeshwari_a\AppData\Local\Temp\tmp3B07.tmp
Deploying 1 data source(s) and 154 design(s) in 43 culture(s) (6623 item(s) total)…
Deployment failed unexpectedly with the message:
Client found response content type of ‘text/html; charset=utf-8’, but expected ‘text/xml’.
The request failed with the error message:
SQL Server Reporting Services
Reporting Services Error
- The report server cannot open a connection to the report server database. A connection to the database is required for all requests and processing. (rsReportServerDatabaseUnavailable) go.microsoft.com/.../](http://go.microsoft.com/fwlink/?LinkId=20476&EvtSrc=Microsoft.ReportingServices.Diagnostics.Utilities.ErrorStrings&EvtID=rsReportServerDatabaseUnavailable&ProdName=Microsoft%20SQL%20Server%20Reporting%20Services&ProdVer=9.00.5000.00) target="_blank">Get Online Help
- Cannot open database "AXDEV" requested by the login. The login failed.
Login failed for user ‘PRELUDESYS\bcproxy’.
Please Help
