SSRS contract class downcast setting null
In the following code, the as operator is assigning a null value to myContract. I have checked everything but could not find anything much of help.
protected void preRunModifyContract()
MyContract myContract;
RecId tmpTableDataRecId;
tmpTableDataRecId = this.fetch();
myContract = this.parmReportContract().parmRdpContract() as MyContract;//setting null to the instance name
myContract.parmTmpTableDataRecId(tmpTableDataRecId);
myContract.parmDesignParam(#ReportName);
if(printDestinationSetting)
this.parmReportContract().parmPrintSettings(printDestinationSetting);
Since, myContract is set to null, the subsequent method calls fail.
It means that parmReportContract() either returns null, or an instance of a type not compatible with MyContract. Please check the value and the type in debugger.
This was weird, I asked a colleague to check it on his machine, and it started to work just fine… After my effort for the past two days.
Thank you Martin!
