SSRS 2012 Report on different language client
I created a report in SSRS 2012 and it runs all good and looks how it should.
But when I start my client in a different language than the mainly used one, the report starts to look totally different and the parameters on the prompt dialog is also messed up (every parameter is shown twice). Also, suddenly no data is shown on the report, but when I run the report in the main language client again, it works all fine.
Does anyone have an idea why this is happening and how to solve?
HI
Did you manage to solve the problem? I have exactly the same problem for two reports.
BR
Jan
Hi Jan,
yes, my problem is solved, but since it’s quite some time ago, I’m not fully sure how I solved it :slight_smile:
Do you have a DataContract class? I think it had to to with that class. Could you post your code of that class?
