When i am opening any of the SSRS reports in MS Dynamics Ax 2012 i am getting the below error
The SRSReportProviderSchema.getAttribute() reflection API could not create and return the AifCollectionTypeAttribute object. Please check the parameters.
Can any one suggest me about this issue and how to solve it.
Thanks & Regards
Arun Garg
hi arun,
first stop the aos services and go to the folder of the xppl folder and delete the all files
start the serivces of aos
and do the incremenat CIL
4)THEN FULLY CIL , THEN ALL THE SERVICE WILL BE STARTED .
THEN YOU CHECK BY RUNNING THE SSRS REPORT …
PEPOLE WHO DONT NO THAT WILL FUCK LIKE ANY THING
AFTER REPORT IS RUNNING PLS GIVE A MAIL THAT IS WORKING OR NOT.
THANKS,
V.SRIKANTH
Hi Srinkanth,
Thanks for the reply,I will try the solution.
Regards
Arun garg
