SqlXml 3.0 Service Pack 3 (SP3)
Available for Download Today. http://www.microsoft.com/downloads/details.aspx?FamilyID=51d4a154-8e23-47d2-a033-764259cfb53b&DisplayLang=en Overview SQLXML enables XML support for your SQL Server Database. It allows developers to bridge the gap between XML and relational data. You can create XML View of your existing relational data and work with it as if it was an XML file. SQLXML allows you to: Build Web Services with SQL Server 2000 Build Web sites to publish data from SQL Server Query relational database with XPath Update relational data as if it was XML Load XML into SQL Server Query SQL Server via URLs, OLEDB/ADO or .NET Managed Classes SP3 includes many fixes since the SP2 release including: Removed Dependency on SOAP Toolkit 2.0 SP2 Microsoft has moved the SQLXML page a few times: Here’s the Link http://msdn.microsoft.com/library/default.asp?url=/library/en-us/dnanchor/html/anch_SQLXML.asp
