SQL-Variant DataType
Is there a quick way of assign Variant as the property SQLDataType for all Code fields in all tables? Thanks in advance. Jesús Soage
Yes, use the Virtual Table 2000000041 Field. There you can directly change the value of all “SQL Data Type” Properties for all Code fields in all tables. Run a Report to do this. Or you can also create a Form based on this Table, filter on Data Type: Code and do Find/Replace. Bye
Thanks Nelson, I will try.
