Hi There, I want to ask you how to insert the timestamp field in SQL Server trigger from another database, couse I have external application want to use to insert the record in database Navision to the NSC table ( table started from id 50.000 ). Means that I want to insert to Navision Database, a single record using SQL Server trigger from other database. for example : when I insert a record in database A, I want that record automatically insert the inserted record to table number 50.000 in Navision Attain SQL Server Option Thanks & Regards, Surya
Please post in the correct forum!!! And do not cross-post![:(] Topic closed…
