We are running NAV 5.01 GB on SQL (Sql Server 2005).
We have a custom development, which among other things reads the SESSION table (Setrange and FIND commands).
Whenever executed, this throws the following error (users have all permission on table SESSION, permissions are synchronized):
"The following SQL Server error(s) occurred while accessing the Session table:
229, “42000”, [Microsoft][ODBC SQL Server Driver][SQL Server]The SELECT permission was denied on the object “Session”,database Navison, schema ‘dbo’. "
When checking the permissions in the SQL admin of the database, then you find the session only as a view (not as a table) and NO permissions set.
On NAV3.7 on SQL Server 2000 and on any native installation this works fine.
Any ideas? Should I manually set permissions on the SQL database Admin for the Session-view?
Thanks for any help.
