Greetings,
I would like to setup Role Center.
Installed Sharepoint Foundation 2010 and Enterprise Portal from Ax setup.
Database verion: SqlServer 2014 Standard Edition 64 bit.
AX 2012 r3 Cu10
When I tried to run Sql Server Analysis Service Project Wizard. I get the following error as in attachment.
I have already set the Fiscal year./Calendar
i
Hey Mazherullah,
What do those errors below the one you have selected say? I can’t see the rest of the error message…
The error as shown on the screenshot. If you click it will enlarge the size of the screenshot.
RHS, I just added another screenshot which shows the entries I have already entered for Fiscal error.
When I run the Deploy on Dynamics AX data under Analysis Service Project wizard. First window it shows saying Fiscal year not set for DAT and ask Do u need to continue. IF you press OK Above Screenshot error comes.
I even tried giving Fiscal Year/Calendar set for DAT. But then only above error comes.
Regards
I am yet to find the solution.
regards
Hey Mazherullah,
I still can’t see the rest of the error messages. Can you copy as a list to clipboard and then post it in here? Looks like there was some problem with the budget cube…
This topic seems to be covered here already…
community.dynamics.com/…/
