Sql Server 2014 - Management Reporter DM db shows as (Suspect)
Greetings,
Today I noticed in Sql Server 2014. ManagementReporterDM database shows suspect.
Any solution.
I tried general ways…like
EXEC sp_resetstatus ‘DATABASE_NAME’;
ALTER DATABASE DATABASE_NAME SET EMERGENCY
this gave me error : Msg 933, Level 21, State 1, Line 2
Database ‘ManagementReporterDM’ cannot be started because some of the database functionality is not available in the current edition of SQL Server.
Note: But when I refresh - It shows in emergency instead of suspect, then I tried below command.
DBCC checkdb(‘DATABASE_NAME’)
it gave me error : Msg 945, Level 14, State 2, Line 3
Database ‘ManagementReporterDM’ cannot be opened due to inaccessible files or insufficient memory or disk space. See the SQL Server errorlog for details.
Memory and disk space is avaialbel.
regards
