Hi
SQL SERVER 2012 Database for Dynamics Nav 2013 Transaction Logfile **.ldf grows up to 228 GB on my server, please advise how do I shrink it.
Hi
Welcome to DUG!!!
Look at the following link
http://msdn.microsoft.com/en-us//library/ms189493.aspx
http://technet.microsoft.com/en-us/library/ms189493(v=sql.105).aspx
What’s your DB’s Recovery Model? How often do you run TLog Backups?
Hi Jorg,
Our recovery model is Full,
But would the empty file affect the database of my NAV when i do recovery? and will the migrated files be just as huge?
A DBCC SHRINKFILE won’t resolve your problem. You need to set up periodic Transaction Log backups, e.g. every hour.
This probably would fulfil your requirements regarding “data-security” and keeping the log-file-size reasonable.
Once you have implemented a sufficient backup-cycle, the ou coould SHRINK the file down to a reasonable size (i.g. 20% of net db-size)
