I am not very skilled in SQL, but had to install Nav Classic Client on a server - 1. an Service was started automatically .
I have installed a new databse, imported the FBK-File. But now, what have I to do on the Client. I just started the client with ‘NAV with SQL Server’, with servername=Name from the installation (service running).
Than I get the message: Can’t find the Server, try later.
Please, can you give me some hints, how to install and connect from the client. I have read the PDF-File for SQL-Installation, but cant go on.
Normally you install Client on the users’s workstation --it takes a couple of minutes-- and on first startup of Client select the server, then database you wish to connect, and that’s it.
If server dropdown box doesn’t show any available SQL server(s) to connect to, it can be everything from user rights to network/domain structure, so it’s hard to give you any hints…
