Hi all! Has anybody a list or something about recommended FILLFACTORs (SQL Server) for NAVISION Tables? Well, I have a “global” idea about that, like - Standard 90% - “Integer only” Primary Key/Clustered Index 100% - The “hotter” the lower (it depends!), down to 50% - … You might know that this is a quite sensible but effective thing [:p] Maybe some of you already have a more detailed list, based on experience!? Thanks in advance! Regards,
