Split String
Dear all,
please tell me , how can i split a lengthy string in a Message???
I W’d appreciate if anyone could answer this
Regards
Rose[:)]
Hi Rose,
I would suggest to use a combination of COPYSTR and DELSTR.
Say you have a string that is max 250 chars, and you want to split it into 5 substrings of 50 chars.
I would do something like this:
FOR i := 1 TO 5 DO BEGIN
IF STRLEN(MyInputString) > 50 THEN BEGIN
MySubString[i] := COPYSTR(MyInputString,1,50);
MyInputString := DELSTR(MyInputString,1,50);
ELSE BEGIN
MySubString[i] := MyInputString;
MyInputString := ‘’;
END;
END;
This is of course a very simple example, but it might give an idea.
In fact you might want to split the string at a given character instead of a given position. In this case you also have to use the STRPOS to determine the position of the character that defines the split.
do you mean to put output a MESSAGE with multiple lines?
That would be done with \
E.g. MESSAGE(‘first line\second line’)
OK…
totally missed that one… Sorry.
The way to define a linebreak in a text is to put a backslash.
So a text-var with this caption:
‘This is my text - Line 1\And this is Line 2’
Would show like this in a message-box:
And this is Line 2
Thanks a Lot. I got It…[Y]
Regards
Rose[:D]
Rose, please mark the message which provided a solution for your problem with a “Verify Solution”.
Ok…I am sorry i Didn’t know that…[:(]
No problem, just remember for future posts please.
