Speeding up Native DBMS backup !
I’ve not been able to see recent posts on that subject, our DBMS Native (4.0) 64GB takes almost 8 Hrs to backup, anyone out there using some magic trick that could reduce that amount of time considerably?!
Tks
Nicolas
If you use a client-backup, you might run it directly on the server.
Or you might use the hotcopy.
For the rest, you can use more RAID1 pairs for the DB-files to increase reading performance and use a RAID10 with some disks to write the backup to.
Of course for best speed: launch the process on the server and read/write on disks on the server (or SAN) (and DIFFERENT disks!).
Native performance = Disks
The fastes way to perform this task is to put the database on a RAID10 or multiple RAID1 set and backup to a different RAID1 or 10 on the same server with a different controler.
Make sure that the read/write cache is optimal.
