Speed and Window-size
Hi, has anyone made the experience, that the speed, with which a form is displayed, depends on the size of the window of the form? When I resize the window of the form only (not of Navision 2.60), making it smaller, the rows are displayed very fast in comparison to a maximized window. The resolution is 1024x768. Michael
Michael : I´ve notice the same thing, I do not know the reason behind this (feature?! [:D]) So I just kept the habit of never maximizing the forms when I work with Navision.
Yes, but I’ve seen quite a few users on client sites that can’t get used to not maximising everything. [:)] I’ve never noticed this slow-down myself though. [?]
Hi guys, If you ever did a trendscape form you would see why. The larger the form is (any list form not only trendscapes) the more rows are being displayed. On normal data there should not be any visible speed difference. But if the form displays flowfields or fields calculated on the fly then the larger the form the more records Navision is running those operations on. Hope that helped. Cristi Nicola
