Special Order - Not connected
Hi! I have found a problem with Special Order. We are using Navision 4.0 SP1. A SO with Special Order are connected PO. But when you post recipes and shipment and navigate the transaction you will find that the transaction is connected with FIFO. Not SO with PO transaction. One of the purposes with Special Order is that the SO should be connected to PO, and the Price could be unique per order. But if the transaction is not connected the statistic of cost will be wrong. Does anyone else seen this problem, and have any solution.
