When I run planning worsheet, get an error description"Assertion failed: Inventory Profile."
Who can tell me how to resolve it?
Thanks!
Thanks!
Hi Harison,
I believe you are using NAV 4.0, if so then this is a known issue and Microsoft has a hotfix for it. If you have access to partnersource, then you can download the hotfix from the following link:
To install this hotfix, change the code in the Prod. Order Line-Reserve codeunit (99000837) as follows.
Existing code
In the existing code, delete the line that resembles the following.``
global text const Text005 = Assertion failed: %1
In the function TransferPOLineToItemJnlLine area, complete the following code change.``
EndLoop := NOT ReservEngineMgt.InitRecordSet(OldReservEntry);
END ELSE
IF TransferQty <> 0 THEN
ERROR(Text005,OldReservEntry.TABLECAPTION);
Replacement code``
END ELSE
EndLoop := TRUE;
Tks,
I am using NAV2009, I try to create a new item(copy the information of the error item) and it is ok, maybe there are some error entry relation the error item.
Harrison
Sorry, I could not understand the above.
Are you able to run the planning worksheet now or still getting same error?
