SMTP Error
I’m working in Nav5.0 SP1 IN and I’m facing an error msg at the time of Purchase Quote Authorization.
How can I solve it ??
Hi
I also have the same error But check your SMTP server Settings…
I have done some changes Now it’s working fine …
Check you have permission for it or not…
also check the Authentication Mode in SMTP Setup
I encountered same problem, you can try the one that i did.
Go to SMTP Mail Setup, Fill in your smtp server, authentication = basic, user id should be your email address and password.
Then try sending purchase quote request. Hope this will work for your
