Slow Posting in SQL
Dear all,
DB is SQL. While posting an item which has more then 50 BOM, in network it takes 15 min to post it. When same posting is done in the local machine the posting is done fast. Wat is the issue behind it.
Regards
Sam
What you are describing it’s a networking problem, increase performance of your network. If you are using wireless don’t use 11mbps.
It is also possible some network card or hub is malfunctioning.
Moved to SQL Forum.
