Hi, We are building an app to allow simple dialing without using TAPI devices (long story but we can’t use it). The problem now is that although I can use Hyper Terminal to send control codes to ring a phone number through a modem, I can’t automate it through Navision. I thought I could use the NFComm.OCX (downloaded from MIBUSO) but with not much luck. With it I thought I could have used the following code; comport.ComX:=0; // 0=COM1, 1=COM2, 2=COM3, 3=COM4 comport.OpenPort; comport.SendStr(‘ATD123’); //example to ring the UK speaking clock comport.ClosePort; Anyone got any ideas on this or used something similiar. Much appreciated. regards, Tim
Just incase anyone has a similiar problem in the future… here is the outcome; I contacted the author of NFCOmm and he offered a clue to solve my problem. I just needed to include CR + LF characters on the end of my string. I did this by defining a couple of CHAR vars and then using FORMAT to add them to the string for “sending”.
