Simple dialog box or page.
Hi Guys,
Does anyone know how to make a very simple dialog box where the user can input a number and click OK? I’m looking for something like the STRMENU function but where the user can input a number into a field - the value should then be brought back to the process which envoked it. Maybe it is possible to make a page which does not sit on top of a source table?
Thanks :slight_smile:
Hi Thomas,
Have you considered using the DIALOG variable? Here you have the functions OPEN, UPDATE, CLOSE and INPUT.
Ohhhh, that could work - will check it out! :slight_smile: Thanks Erik!!!
Hi Erik,
I tried to make this work but it seems this particular Dialog.INPUT no longer exist in 2013 onwards.
I did find an article describing how to do this with DOTNET: http://saurav-nav.blogspot.co.id/2014/09/discontinued-component-nav-2013-later.html
I followed the instructions and it worked :slight_smile:
Thanks!
Hi Thomas,
That’s why you should always write which version of NAV it’s about.
Thanks for the link. If you need more than one field, then you would still have the option of using a page as you suggested.
