SIMCREST - navision logging tool ???
Hi Has anybody some experience with that tool? Sucessfully running it under navision 2.60 with its own database on a windows nt 4.0 server? We have more than a standard navision because a company has made some changes to the standard navision program. How much more space will our navision database need with that logging tool? In the moment we use 14 GB from 32 GB. Would the performance of our navision clients become slower when using this logging tool? Thanks!
I have implemented a solution like that. The client wanted to log changes on the customer records. It works good, the user can decide how extensive the logging is going to be, so you could start out with extensive logging and then decrease the logging actions (A Superuser in the system could do that through the setup tables.) if you want to bring down the logging data amount.
