Signing the model files while exporting.
I have been trying to export the signed model and import the same.
For that, I have generated the .snk file from VS cmd prompt and ran the following command in AX management shell to export the AX model file,
Export-AXModel –Model “xxx” -File " xxx.axmodel" -Server “xxx” -Database “xxx” -key c:\keys\mykey.snk
The model has been exported successfully.
But while importing it prompts the following message,
The model is not signed. Are you sure you want to install this model (Y/N)?
The importing command is,
Install-AXModel -File “xxx.axmodel” -Server “xxx-1” -Database “xxx”
Am I missing any step or parameter in import command? Anyone please guide me.
Alen Franklin
