What is significance of STX file. It is used with Developer Toolkit. What information is stored in this file. If anybody knows pls. update me. Thanks
The STX file “contains general texts used by C/SIDE”, as shortly described in the Application Designer’s Guide PDF-Manual.
You can open and read it with Notepad application, but you can’t edit it.
Thanks guys. I got it PH. Thanks.
