Dear All,
I want to show only limited financial dimension on some forms. I did all the things as per the blog(shankardynamicsax.blogspot.in/…/disable-financial-dimensions-in-ax-2012.html &shankardynamicsax.blogspot.in/…/only-show-required-financial-demensions.html). It worked fine for CustTable, VendTable and SalesTable forms.
But for PurchTable form, it is not working.
When I called the method parmEditableDimensionAttributeSetId() with both the object(dimensionDefaultingControllerLine & dimensionDefaultingControllerHeader), the purchTable form was not responding properly.
dimensionDefaultingControllerLine.parmEditableDimensionAttributeSetId(dimensionAttributeSetStorage.save());
dimensionDefaultingControllerHeader.parmEditableDimensionAttributeSetId(dimensionAttributeSetStorage.
But when I called the method parmEditableDimensionAttributeSetId() with object dimensionDefaultingControllerLine only, it was working fine for only LineView mode.
What to do to show only limited dimension on both the view(LineView & HeaderView) of PurchTable form?
Note: In SalesTable form, there are also two object(dimensionDefaultingControllerLine & dimensionDefaultingControllerTable). I called the method parmEditableDimensionAttributeSetId() using both the Object, it is working fine.
Please help ASAP.
