In a report I want to show the department name in Service Shipment Header section.
I have “Service Shipment Header”.“Shortcut Dimension 1 Code” and now I need the Name.
As usualy I created a new global variable named DimValue - Recor Dimension Value and created this C/AL on:
Service Shipment Header - OnAfterGetRecord()
CLEAR(DimValue);
IF (“Service Shipment Header”.“Shortcut Dimension 1 Code”) <> ‘’ THEN
IF DimValue.GET(“Service Shipment Header”.“Shortcut Dimension 1 Code”) THEN;
But this time the name does not appear on report, I don’t know why???
thanks
DRB
2
What is the source expression of text box, supposed to display this NAME?
Hy
The source expression of text box is DimValue.Name
DRB
4
The Primary Key of Dimension Value table is Dimension Code,Code, which means while using GET statement for DimValue you should specify two parameters:
Shortcut Dimension 1 Code (Area, Project or whatever is your SD 1), you may get it From G/L Setup
Value of GD1, in this case
So
GLSetup.GET;
CLEAR(DimValue);
IF DimValue.GET(GLSetup.“Shortcut Dimension 1 Code”,“Service Shipment Header”.“Shortcut Dimension 1 Code”) THEN;
PS (Edit): Define GLSetup as Global Variable , Record, 98
Sorry , but GLSetup does not have the name Dimension code, so I must get Name field from Dimension Value.
But I don’t know how???
DRB
6
Did you even try the suggested solution?
I have suggested changes in code, you need to just copy & paste it, don’t change the sourceexpression of your text box.
Try this and come back if you face any problem
Dhan
You are right.
I implemented your solution but changing my source expression, that was the problem.
Every thing is ok now.
