What is the use of Shipment on Invoice and Return Receipt on Credit Memo on sales setup window .
Plz tell me iam little bit confused on how to n where to use them
You do not have to create a sales order and ship and invoice the goods. You can create a direct invoice for the items. If you do this you do not create a shipment record - unless you tick the shipment on invoice box, then the shipment record is also created. The same is true where you create a credit memo, instead of a return order.
Thank u Adam its very clear to me now
Do not forget to verify the solution, it then gets a green tick so others will not read it to try and answer it.
