amudha
1
I want to use Inventory Items in a Virtual Company. Can anyone tell me how to share the tables that are used on the InventTable form.
I want to share the following tables:
INVENTTABLE
INVENTTABLEMODULE
INVENTITEMLOCATION
Can anyone help me out in explaining what are the steps involved in it?
Thanks in advance!
Regards
Amudha
Hi
If you want to share the data:
Create Virtual Company.
Add some Company account into the virtual company
Add some Table Group in (you may have to create a new table group contains InventTable, InventTableModule, InventItemLocation)
Then your data will be shared through this companies.
Something you should remember:
You have to consider sharing the master files of Item (Item Group, Model Group,…) also → it may cause some problems on the set up structure.
If you already have some Item Data, then you have to change the value DataAreaId to the VirtualCompanyAccount afterwards.
Hope this help
