hai all,
Can any one say the table name which should be shared in order to share the item master in virtual company in ax 2009
regards
jismon
hai all,
regards
jismon
You should share the following tables:
inventTable
inventTableModule
inventItemLocation
I would recommend you properly look at the item structure, then match this to what you want to achieve from the share, then decide on any processing pitfalls.
