settmpdata()
hi All,
wt is the use of Settmpdata() ;
Regard’s
Nani
Hi Nani,
A good artical written by Arjit
http://daxguy.blogspot.com/2006/12/temporary-tables.html
Refer this will help you surly…
Thanks & Regards,
Mehul Thacker
You can now add, modify or delete data from the table without affecting the real contents stored in the database.
Using temporary tables in forms requires the use of the .setTmpData() method.
