Setting BOMLine Qty on Product Configuration using PcAdaptor API
Hi!
I created a new product configuration model using the product configurator.
Now I would like to set the quantity field on the Subcomponents > BomLinesDetails > Setup > Quantity, from code, based on the selected values for the product attributes.
All I found on the Web is this blog article, but after creating a class it never gets called.
http://blogs.msdn.com/b/axsupport/archive/2012/04/13/product-configurator-calculating-decimal-bom-quantities.aspx#comments
For testing I create a new Sales Order, set a item variant of my product configuration on the line, go to Product and Supply > Configure Line, and after setting all the values, when I click OK my class should be called, but it’s not :slight_smile:
Does anyone have any ideea why it doesn’t get called ?
Thank You!
Hello Catalin,
In order to be able to use your class, you have to clean the caché. In the development enviroment, go to Tools - Caché - Update Data Dictionary/Update Data/Update Elements. Then your class will be called from Product Configurator.
