Item.SETFILTER(“Date Filter”,’%1…%2’,“Should be less than start date”,StartDate);
I need to set a date filter with no start date and only end date.
i.e: all the records before start date.
i.e: (where date < ‘2017-02-05’)
Please Help.
Please Help.
Hello,
a simple IF condition should do it.
IF StartDate = 0D THEN Item.SETFILTER(“Date Filter”,’…%2’,EndingDate) else Item.SETFILTER(“Date Filter”,’%1…%2’,StartingDate,EndingDate)
best regards,
Thank you for your quick reply…!!!
No problem!
I’ve made some mistake in the above code.
The bolded part should have been %1, but i think you have found this out yourself.
Corect code:
IF StartDate = 0D THEN Item.SETFILTER(“Date Filter”,’…%1’,EndingDate) else Item.SETFILTER(“Date Filter”,’%1…%2’,StartingDate,EndingDate)
best regards,
