SETFILTER Overflow
I need some help with SETFILTER and the maximum length of the filter to be applied to a Code(20) field, in NAV 2009 Classic Client.
I have this form that prompts the user for some filters to be applied on a table. One of these filters is going to be set on the “Shortcut Dimension 3 Code” (which is a Code(20) field) using the following code:
RecAbc.SETRANGE(“Shortcut Dimension 3 Code”, txt_filter);
(txt_filter is a Text(250))
If the user types something like ‘LHCHPL|REOC6|CIHJM|REOC7|LHIRS|CHPLEMC’ I get the following error, even before the debugger starts:
"a value of the filter is too large for the field type: Type: Code 20"
But if I break the txt_filter in half, the code executes perfectly. If I run the table and set the filter manually I get no error and I get a set of data.
I am puzzled [:S]
I don’t want to reformulate the logic that I have already coded but if there is no other way…
Thanks once again!
I made a mistake, I meant
RecAbc.SETFILTER(“Shortcut Dimension 3 Code”, txt_filter); or RecAbc.SETFILTER(“Shortcut Dimension 3 Code”, ‘<>%1’, txt_filter)
Another strange thing, if I set the filter statically like
RecAbc.SETFILTER(“Shortcut Dimension 3 Code”, ‘LHCHPL|REOC6|CIHJM|REOC7|LHIRS|CHPLEMC’);
the code executes without any error…
Anyone?
