Hi Gary,
Please always remember to write or “tag” your posts with the appropriate version of NAV. Makes it easier to answer your question.
But no, there is no limit of 20 chars when setting a filter. Your filters can be like ‘1243124|132414141|142323|1234532’ etc. Just remember that each individual number you are filtering on cannot be longer than 20 chars.
HI Erik. Yes you are right, I am misunderstood the eroor, in fact , it is the limit of the field, such as I wrote the code : seltfilter(“Item No.”,‘11111111111111111111111124324324’), it throw the error, it means the limit of the “Item No.” is 20, I can not set the filter chars more than 20…, At last I found the solution, I use temporary table to record such many-to-many relationships.
