i been trying the above filter on the Location table. As it shows am tryin to show records that start without a Z. using Nav4 SP3 (native database) and windows vista. the result is all records including the ones with a Z at the start are showin up. mind you, if i specify a particular location (SETFILTER(Code,’<>%1’,‘ABC’) then yes it works fine.
to check have tested the above filter directly on table(F7) and report(data item view prop) and the result is the same. Am for one not sure whether this has been the case all along in all versions or is it only with new version or with vista.
many thanks
