hai all…
how to set visible (Text box or label) in report ??
thanks
hai all…
thanks
Hi Stan,
As far as i know, that can not be done runtime.
But you can either design 2 almost identical sections (only diff. i the controls you dont want printed), and then use CurrReport.SHOWOUTPUT to define wich of them is printed.
Or You can put a textvariable as the SourceExpr, and then either format the field-value into that, or make it empty if you dont want the field to be visible.
(you could look at report 206, and the way the CopyText-variable is used to add ‘Copy’ to the document type in the header)
o… i see
i know that we should make 2 section
for currreport.showoutput like that
i though it could be more simple bu setting visible
thanks sander
