Have you tried set up many Ax on the same server with the version 4.0?
In version 3.0, I can just copy the application files, and change the configuration setting using 2 tiers. But I am not sure it is possible in version 4.0, where they removed the 2-tiers and then I have the problem with AOS…
Can anybody help?
