Hi
I am new at ax 2009.I created a form with a few tabs.When i open the form the scroll sets down, so the bottom of the form is seen.How can i set the scroll up?
Thank you…
Hi
Thank you…
you mean scroll on a grid ?
Hey,
according to my understanding the issue you are facing is that the grid shows the bottom most or the last entry, right ?
If so, check the Start Position property on the datasource of your form. If it is set to last, change it to first. Hope that helps!
