Set as default filter column not working
Here set as default filter not working for any of the column
Hi Seemab,
Is the table your looking up a temporary? Which table is it?
How can i find that this table is temporary or not ??
i simply created a table and added 4 fields and added this table in sales lines.
Hello there
Your problem is that the table that you have as a dropdown list - Does not have the field you want to set as default column filter as a sorting key. EG. Table 13 - Where users quite often want to set Salesperson Name as the defautl filter Column is not possible until you go into Development Client. Choose Table, Select table 13. Alt+D for Design, View, Keys and add a new sorting key as Name.
[deleted]
My query is resolved. THANK YOU…
