Hi.
I have a problem with the Session table of Microsoft Dynamic NAV 2009 SP1 (6.00.29626) in classic mode (native database).
The problem is that there is a white space in the prefix of “User ID” column.
I think that this is a bug and i ask to you if there is a rapid solution/patch for resolve the problem.
Thanks.
It is probably a bug (or a new way to see if you are using sql vs. native db :)), but no fix available yet if Waldo’s list is up to date: http://dynamicsuser.net/blogs/waldo/archive/2010/03/10/platform-updates-overview-3-70-b-nav2009-sp1-updated-3.aspx
Instead of patching your code, i would recommend that when you do a look up in the session table, that you dont do it based on the “User ID”, but use the field “My Session”:
SETRANGE("My Session",TRUE);
IF FINDFIRST THEN ....
That way you eliminate the issue you are facing!
HI SNielsen,
Thanks for your answer.
I think so because in the same version on SQL there isn’t that problem.
Your advice is useful only to see my session but not If I want to see if another user is connected.
So keep looking for a hotfix.
So for now just filter with the prefix. If this is in a customer specific database, that should be easy to handle. If you needed to check the ApplicationBuild, to make your filter conditional, you could always check the ApplicationBuild() function in codeunit 1 (just remember to update it, when you upgrade executables, as it is not the same function as called when doubleclicking the version number in the about screen :)).
