Services starting problem for RTC
I have two services in my system one for SP1 RTC and other for R2 RTC.Only one service at a time can be in Start position and other service if i start means giving error as
“The Microsoft Dynamics NAV Server service on Local Computer started and then stopped. Some services stop automatically if they are not in use by other services or programs.”
Please solve my issue…Thanks in advance…
You need to Use NST Management
Look at this link
http://www.mibuso.com/dlinfo.asp?FileID=1337
Is Net.TCP Port Sharing started?
Problem is both services have same executable path(Right click on Service—>Properties---->Observe the “path to Executable”).So to modify the executable path.
here is the trick to change the location of service without reinstalling it.
just type regedit on Run, Then go to following path
  • HKEY_LOCAL_MACHINE
  • SYSTEM
  • CurrentControlSet
  • Services
  • Service_Name — imagePath, just change the value of Image Path to new location.
