Server not found
Our client has windows server 2008 and sql 2005 and all workstation is at WINXP SP2. when connecting to the server its giving me an error “Server not found”. Please help.
IAN
Hi!
Is the “SQL Browser” Service aktive? If not, then start it and try to connect. Does this error occur only if you try to connect via the Server-Name or is it the same if you connect to the Server-IP?
REgards,
Jörg
Oh, and I just realized …
Welcome to the “Dynamics User Group” [<:o)]
Thanks Mr.Jorg.
Deepak G Nair
Hi Jorg,
Thanks for the reply, Yes its doing the same problem whether you try to connect via name-pipes or by IP.
IAN
And the “SQL Browser Service” (please check the SQL Server Configuration Manager?
What User Account is used for the “SQL Server Service”? If you run it with a DOmain-Administrator Account, does it work then?
