Is anybody familiar with the following : we try to restore a database on a server. We had to enlarge the database to fit it in but when generating indexed Navision gives a message like this : The server sends the folowing message. When you press OK there is a message that de disk is full. That’s a strange message because the database should be large enough. Is it possible that this has to with the internal memory (the usage of the server processor was 72%) or does Navision use swap space outside his own database and how much has to be free then ???
This is probably caused by the navision server trying to write a temporary file to the disk.
Did you check the space on drives of Server where SQL Server is installed?
