serial number in quality order form
hi all,
i want serial number lookup in quality order line result form (InventQualityOrderLineResults) which serial number is fetched from the purchase order registration form(inventtransregister). In the lookup i want all the serial number for a perticular item which is generated after spliting the item.
i write the code in the validate write method of InventQualityOrderLineResults form.
public boolean validateWrite()
boolean ret = super();
InventTrans _InventTrans;
InventTransOrigin _InventTransOrigin;
InventDim _inventdim;
InventQualityOrderTable _InventQualityOrderTable;
str 100 referenceid;
select _InventQualityOrderTable where _InventQualityOrderTable.QualityOrderId == this.QualityOrderId;
select _InventTransOrigin where _InventTransOrigin.ReferenceId == _InventQualityOrderTable.InventRefId
&& _InventTransOrigin.ItemId == _InventQualityOrderTable.ItemId;
while select _InventTrans where _InventTrans.InventTransOrigin == _InventTransOrigin.RecId
select _inventdim where _inventdim.inventDimId == _InventTrans.inventDimId;
this.RFL_SerialNumber = _inventdim.inventSerialId;
this.setTestResult(null, false);
return ret;
by this i get first serial number not a selected one or not a lookup of all serial numbers for a perticular item i also write the lookup method in the newly created field but by this code i get the lookup of all items not a selected one.
public void lookup()
SysTableLookup sysTableLookup = SysTableLookup::newParameters(tablenum(InventQualityOrderLineResults), this);
Query query = new Query();
QueryBuildDataSource queryBuildDataSource;
QueryBuildRange queryBuildRange;
sysTableLookup.addLookupfield(fieldnum(InventQualityOrderLineResults, RFL_SerialNumber));
// sysTableLookup.addLookupfield(fieldnum(InventQualityOrderLineResults, inventDimId));
//BP deviation documented
queryBuildDataSource = query.addDataSource(tablenum(InventQualityOrderLineResults));
queryBuildRange = queryBuildDataSource.addRange(fieldnum(InventQualityOrderLineResults, RFL_SerialNumber));
// queryBuildRange.value(Global::queryNotValue(InventQualityOrderLineResults.inventDimId));
sysTableLookup.parmQuery(query);
sysTableLookup.performFormLookup();
i am not understanding what would be wrong.
can anyone give me the solution.
